Thematic Air Con Problem
Geez1000
Warwickshire
E320 CDI W211
I have a 2007 S211 E320 CDI.
The problem I have is when the air con is on and both temperature controllers are set to 16 degrees or full cold, the air vents on the left hand side of car throws out colder air than the right.
It's the same for the 2 centre vents, the left being much colder. However, if the air con is off, both the output temperatures seem to be the same.
It seems like the conditioned air is not getting through to the right hand side of the car.
The centre vents in the rear has cooler air coming out from the left.
Has anyone experienced anything like this before or got any ideas?
Thanks Geez 1000
Did you get a solution? Mine's the same!
If its the actual unit that controls it... I have a spare one knocking around that could be forsale
