Third brake light on 2005 SLK R171
Mercedes1008
Warwickshire
Mercedes SLK
Third brake light not working so I am trying to test if it is a wiring problem or the light itself. I have removed the plastic cover under the boot lid ok and there appears to be a plastic assembly within the boot lid itself held in by two clips on one side and three on the other. I can ease off the two clips on one side but the three on the other side seem really firm. I assume I need to get this out to complete my electrical testing. Note: I also removed the long thin panel on the back of the boot lid which house the lock and number plate illumination lights but this does not seem to help me access where I need to get to. I have attached a picture showing the plastic assembly within the boot lid and highlighted one of the three clips that is resisting being removed.
Any help advice appreciated.
GeeJayW
NW Blighty
S205 C250d AMG Line P+, MX-5 25th Anniversary Edition
Wish I could help. As no-one else has chimed in, I suggest you also search or ask the same question over at the SLKworld forum. Good luck.
OP
OP
M
Mercedes1008
Warwickshire
Mercedes SLK
Sorted now. The secret is you remove the side with the three clips first. This can be done by applying upward pressure on the plastic assembly itself and then easing the three clips off backwards one at a time. Once this is done you can slide the two on the other side off easily. Then with a bit of juggling you can extract the plastic assembly out of the boot lid to expose the third brake light and its fittings.
Mikeeuropa
Derbyshire
SLK R171
Thanks for bothering to come back with the answer, so many people tend not to 🙂. I'm just trying to sort this on my wife's SLK and was wondering exactly the same question. Where did you get your replacement from?
OP
OP
M
Mercedes1008
Warwickshire
Mercedes SLK
Mercedesbenzofnewcastl
mercedesbenzofnewcastle on ebay
Dodger76
UK
2006 SLK 200 R171
Thanks for the info regards removing 3rd brake light, but not sure how much upward pressure is needed to release the three clips.
