Timing chain cover leaking oil
Aded
Manchester
W204 C180 2012
Hi all.hope all well.I sorted out my oil filter housing last week and the oil stopped from that area.my other oil leak is in the front around the chain cover.it looks like coming from top corner of lower time chain cover.if it is the top one can can manage to do it but it looks like from the lower one, which is difficult to fixed, bcos most of the video said sump need to come out.It is just small dripping from top to down. It was my former mechanic that did the chain slide rail that did those stupid job.Is the any silicon I can put from the top corner on top to stop the leak without removing the cover.thanks w204 c180 cgi
Check it is not the turbo oil feed line O ring. Very common to also fail and leak oil and make a mess around the front of the engine.
Details and parts numberd to be found here:
You dont actually need to replace the line itself but must replace the other parts including the banjo bolt as its one time use and has a revised check valve that the original does not.
I replaced the o ring on that like 2 years ago and it looks right now , no leak from that side.👍
I replaced the o ring from turbo line like 2 years ago and it looks fine when I checked right now , no leak from that side.👍
