Tinytots
Hi all, I'm having major problems changing my diesel pump. The mechanic doing the work is trying to confirm what degree the timing should be before fitting the locking bolt. He is fairly sure it is 17 degrees. The other problem is the pump won't lock, there seems to be a break on the lower shaft or the wheel at the rear of the pump that has the locking pin on it. The tool works perfectly on the replacement pump, but not on the old one. If he sets the timing at the right degree and removes the old pump, then locks the new pump and puts it on will it work?
Please help, I've now been without my beloved Mercedes for 5 weeks now, nightmare.
