Bellow
Hardcore MB Enthusiast
I have a couple of questions relating to TCs that hopefully someone here can answer.
1) On the surface of a TC that faces the engine flywheel there is at its centre a smallish diameter (coin sized) protrusion. What is its purpose? Does its external surface form a spigot that engages and centres the TC to the flywheel/flex plate? Internally does it have a function eg, houses a bush or bearing that supports the turbine?
2) Torque capacity - is there a limit?
I know that some members here have tweaked the MB 6cyl diesel to torque levels way beyond stock. Has this been in conjunction with an automatic transmission and if so, did the TC handle all the torque without protest?
TIA.
edit PS.
My questions relate to the older style non-lock up TC, specifically, the Ford C3 unit.
TIA.
edit PS.
