Glenn Smith
- Mar 7, 2006
- 2000 c230k estate
I was just reading the post on the Valeo radiator issue, i see that in the diagnosis they refer to disabling the torque convertor lock up clutch, my c230k (202) has the 722 6 transmission with tip shift, but does not appear to have a lock up clutch, is this correct i wonder? did some have it and some not, i haven't seen any reference to it in the drivers manual either, i never feel it engage, i would assume it only operates in top gear above a certain speed as my jag does (around 53mph) and is quite noticeable when you accelerate that the drive is then direct.
