jaiscossie
- Nov 15, 2009
For sale is my totally immaculate Palladium silver Mercedes E-class estate. The car has been my pride and joy and has had no expense spared in my ownership over the last 4 years. I am very meticulous and overly fussy with my cars. It has thousands of pounds spent on maintenance and perfecting it. It had a brand new rear subframe replacement by Mercedes Benz and all new brake lines also fitted by them, this is a common fault on the w212 model and I wouldn't purchase one now knowing this without this job being done which is over 2000 pounds. The car has also had the following, full wheel refurbishment by Wheel Worx, they are unmarked and fitted with new Mercedes-approved Pirelli tyres, new centre caps, wheel bolts etc, A major service in the last thousand miles all filters and fluids including the auto gearbox were changed using the correct MB oils. It has a great service history, always serviced every year from new and every 10k miles or less. New brake discs and pads all around, brake fluid and coolant change. New Varta OEM battery and the car has stop-start which works perfectly, new windscreen was recently fitted, everything works on the car as it should and there are no faults whatsoever, the climate control is nice and cold also. The car has always been valeted and detailed by myself and has been clay bared, ceramic coated and the leather cleaned and protected. It has been a non-smokers car and no pets, rare for an estate I know, it has barely even had anything in the boot. The paintwork can only be described as immaculate, with no chips, scratches or dents anywhere, inside is equally the same and could easily pass as a 2 or 3-year-old car it's that clean. The car drives beautifully, is super smooth and is very economical on a run easily reaching 45+mpg, it is HPI clear with report, a fresh mot will be put on prior to sale and the car will go back on its original 12 registration plate. The car comes with a ring binder full of receipts for every penny spent, all original handbooks and also two keys. A set of OEM rubber mats and also carpet mats included and a boot liner which has always been fitted. I am reluctantly selling now as my son has passed his test and I am downsizing to a smaller car. You will not find a nicer E class of this age or price range in the country I can honestly say that.
The price is £9750 and the car is in Suffolk
Thanks for reading.
Thanks for reading.
