I read that the tourist mode setting on the 2010 E Class Saloon can be set by pressing a combination of buttons on the steering wheel. Is this true? I thought the switch over had to be done at a dealers on a laptop.
Unfortunately not so! I bought my car new in Jan 2010 and the manual says the change to/from tourist mode has to be done by a dealer. The latest manual on the internet does say that it can be done via the 'Lights' sub-menu by changing the dipped headlight setting but that option does not appear on my sub-menu.
Well, you do not say which lights you have, this menu option should appear for Xenons only (if I remember right).
I think so - AFIK automatic Euro/UK setting is only possible with Xenon HID's.
Thanks chaps! Yes I have the Xenon Intelligent Light System so I'm surprised that it isn't available on my car. Perhaps a software upgrade is required? I will take it to my local MB dealer and seek advice. I have recently brought the car back from the continent where the lights were set to tourist mode (flat Xenon beam) by a German MB Dealer.
From the WIS doc.
"In model 207 and model 212 up to 30.11.09 (YoM 09/2) with bi-xenon headlamps, the headlamps are adjusted electronically using using Star Diagnosis.
In model 207 and model 212 as of 1.12.09 (YoM 09/2) with bi-xenon headlamps, the headlamps are adjusted on the onboard computer using the instrument cluster."
So very much depends on when exactly the car was made..
What is tourist mode?
