How about mounting on the A-frame? There are racks commercially available. Need to check the permissible nose weight though.
If you have a good weight ratio then stability would certainly be less of a concern, particularly with a folder that has a lower
How would your fore/aft channel pieces be attached to the caravan - do the chassis rails go back far enough to bolt them to those?
