Hi, No. I wouldn't advise it. If your nearest power supply is the cigar lighter on the console between the front seats, it's that or from the battery direct. Bear in mind that those cigar lighter sockets can be fused for pretty high amperage, so better use a smaller fused link on the cable, as near the socket as possible.
Its not such a big deal running a cable direct from the battery to the boot either, especially if you have access to a lift. Same conditions apply... fusible link, as close as possible to the terminal. I've done it several times, and is a bit awkward, but not too much either. Best of Luck with it, and you are lucky in that in the 2012 E class, the brake and park lights are standard bulbs, needing a separate feed, unlike the 2014 E class,,they have the new system, one micro cable supplying both brake and park lights
