Since you have a W124 , with bulb monitoring circuitry , you either have to get the Mercedes wiring kit and connect 'upstream' of the bulb monitoring unit , or use a multi-relay which only takes switching voltages from the light units without affecting loading - again DIY fine if you understand what I'm talikng about , otherwise best pay someone to do the job for you .
