Hi all-Our MY2014 SLK has TPMS but I can only get it to display the tyre pressures in Kpa, not PSi. I have been through the menus on the cluster and can't find an option to change this. Any ideas please?
If you search I'm sure there was a thread on this not long ago, can't remember the answer though. The owners manual also quotes pressures in kPa which is daft. A decision made by men in white coats. It might technically be the correct fundamental unit for pressure but kPa is hardly in common daily use outside of a laboratory. What's even worse is they are just Bars with some noughts added. Bars I could have coped with.
