SLK350
Anyone suggest a good Tracker type device.
Also anyone had a good (or bad) experience of using one.
Both my Current CLK500 and my new car has one fitted.... I suppose its piece of mind...
Tracker definitely recommended if it is a high value car or stealable car. Never had one stolen but have had to use tracker once to my embarassment. Once went on a business trip ended up running late and dumped the car in the car park at Stanstead came back a week later went to where i had parked the car and it wasn't there 60 minutes later I still couldn't find it. Rang tracker who checked the system they confirmed the car had not moved for 7 days, then they obviously have an overlay map because they told me exactly where it was parked. I have also rang them from some very obscure remote places for a confidence check where they tell you where you are and they have been bang on every time. Well worth it to me and all our cars have them.
I thought these devices were about the size of a cigarette packet? So there must be lots places to hide it.
Different companies offer different services. For some, you tell them when your car is not in use, if the car moves during that time they will contact you immediately.
Other services are more passive. You must inform them when you think you car has been stolen, then they pass on the details to the Police. I guess this option is not recommended if leaving your £150k car at an airport car park.
They scan for the device and simply remove it, very easy with right equipment. Also the places that fit these things always use the same places dependant upon the type of car, M3s for example they usually drop the glove box and fit behind there, i had two fitted and both were put there so not hard to know where its most likely going to be located even without a scanner.
