inetd
- Jul 5, 2004
98 S500, appears to have a fluid line/hose coming from the trans drain plug, runs up into the grill area. Haven't located the trans fluid radiator yet - if there is one somewhere.
Assuming this IS a tranny cooler line?
This line bolts down to frame here and there along its length. One is a loop bracket that screws into the engine oil pan. And it's stripped - it was just hanging there! The threads are stripped in what appears to be the aluminum bottom of the block. Ok, sorry for rambling, here's my point:
This trans fluid line runs at probably the lowest point on the bottom of the car. Was there some protection for this line built into the design that I missed? I'd never know if I ran the tranny dry, other than about $2k missing from my $1k checking account. But with no dipstick, I'm sure computer would gripe AFTER damage is done. Is there such a thing as a permanent dipstick (leave-in)?
Also, recommendations on that stripped female into the oil pan/block, and perhaps a hose re-route to a safer location?
Thanks again!
Thanks again!
