Michaell
Hi Guys, hope you can help i recently had a wobble on the front of my b200 cdi 07 plate car and after investigation i later found that one of my cv boots was leaking oil on the left inner cv which the garage failed to tighten on properly. You don't notice these things until you see grease on the wheel. So i took it back to the garage and they refitted the the cv boot with a better clip. However 2 weeks have passed since then and i was advised the the drive shaft that could of run dry needed to be replaced which i got done..no more wobble until ive noticed in the last few days the automatic gearbox seems to not run into gear as well as it did, Also when i put the car in reverse it sort of shunts back rather than engage correctly then today the car would not go past 40 as if it was in safe mode. I stopped the car and restarted it then a warning appeared on dashboard saying " transmission failure please visit work shop" I'm a little confused because the car started driving ok without a limp being present. Could this be the drive shaft that's just been put in not engaging correctly or could it be gearbox or gearbox oil? As much as the car has been a great workhorse I'm tired of spending on it with idiot mechanics doing crap work.
Any ideas would be perfect please.
Regardz
Michael
Regardz
Michael
