Transmission code reader help needed..
bandit2510
Coventry
CLS 320 CDI
Hi anyone in the Coventry area got a fault code reader as may have a transmission fault. Would like to see codes before just getting fluid replaced. Thanks in advance.
Yes I do. Where abouts are you?
Possibly tomorrow afternoon if not then Monday afternoon is doable if that's any good?
Hi bob6600 I'm only in Rugby and also having some issues with my transmission would it be possible to come to you on Monday if your available to see if there are any codes on my E280
Sent from my SM-G925F using Tapatalk
bob6600 will find out how to pm and send you my contact details. Sunday/Monday would be fine. ty
sorry cant find out how to pm as im relatively new member. if you could message me i will get back to you asap.
PM me
Have emailed you
Not received, not sure how to get around this. You could try asking a mod to enable PMs
i have contacted the mod to get my pms activated.
You PM feature will be activated automatically once your post count reaches 30.
Not sure if the mods can/would override this.
apparently i have to have 30 posts before pms are activated so will try and email you again via gmail? the email address i have for you starts coool is this correct? if not i will put on my mob number and then delete it after you have seen it.
They can and they do sometimes, depending on the circumstances
@bandit2510, that email is incorrect/not used but let me see if I can access it
they can and they do sometimes, depending on the circumstances
@bandit2510, that email is incorrect/not used but let me see if i can access it
ty bob how strange about the pms lol
OK I've got it and have emailed you via another email addy. You can edit your number now :)
I haven't forgotten about this gents
