johnny679
- Aug 18, 2019
- Location
- east sussex
- mercedes c180 , 95 honda civic coupe turbo , Triumph Spitfire
Hi All
recently had a big problem after loosing transmission fluid ,then car lost drive ,jumping out of gear going into limp mode , drained oil ,dropped pan and cleaned , fitted another valvebody and conductor plate , fresh oil and flushing additive , drained oil , more oil to flush out any old oil , drained , dropped pan to clean , add new filter and more oil and finally took for a test run and all running and changing gear smoothly , all thou im getting a P0138 code which i think is a oxygen sensor , car has been laid up a few months could this of caused the code to flash up , would it do the car any harm to run this for a little while , also dash warning saying coolant level check but level is perfect but could the sensor need a clean?
