Hi all, is there anybody in the North West that can do a transmission fluid change on my W202 2.8 V6. I used a dipstick to check the fluid while it was cold and it seems to be too full. When I removed the cap the seal is soaked. There is no red clip either although I’ve just bought one.
This leads me to believe that at some point someone has overfilled it.
I don’t mind doing it myself if I knew exactly how much fluid should be going in and what to check the temperature with in the absence of STAR or iCarsoft (which doesn’t seem to work well on W202s).
Thank you
Thank you
