Hey guys i have a 2001 c270 cdi 80,000miles.. I got the car a few weeks ago and and i put my foot down it jumped out of gear then put it in neutral and back into drive and it was fine, then the next day it got stuck in second gear i had to turn ignition off and on and its fine until i floor it again.. then a few days later it got permanently stuck in second gear and wound not reset even if i turn off and on the ignition.. so i took it to a garage and they put there diagnostics on it and reset it and i got the codes and it was changing gears but would still jump out of gear and get stuck but i could still turn ignition on and off.. then again it got stuck it second gear permanently so again to the garage got it reset but this time they wound not give me the codes.. also it feels like the car doesnt want to change like jerks a few times before changing and sometimes it drives perfectly like its brand new.. it still has the Mercedes seal for life on the transmisson fluid so does that mean its never been changed?? iv seen on the forms people are saying it could need new transmisson fluid or needs a new electroplate?? here are the codes the first time i took it to the garage
014 RPM Comparison N2 To N3 Implausible
110 RPM Comparison N2 To N3 Implausible
136 CAN Communication Disturbed Electronic Ignition System Module Or IC
146 Inadmissible Transmission Ratio
does anyone know what these codes means??
thanks alot for any help, means alot its my first merc
