I changed the radiator on my mum's 2002 slk320 yesterday as the little plastic pipe on the top nearside had cracked.
I had to remove the transmission lines from the radiators together with the coolant pipes. I'm guessing that I lost about 0.5 litres of transmission fluid that was inside the lines that I removed and also some that drained out from the gearbox side.
Do I need to replace this loss? If so, can I do this without having to fill from under the sump? Do I need to use MB fluid (I read on Pelican Parts that this was required, but I have some spare ferrari fluid that I could use)?
Many thanks
Many thanks
