transmission, shudder
strity
mercedes benz vito
Hi all,
I am experiencing a shudder/vibration in my MB 115cdi Vito van. Can anyone tell me what may be causing it?
BlackC55
Portsmouth, Hampshire.
E55K SL500 E300Hybrid E250X3 Viano C55 E450Cab A180 Smart 44 Brabus
A worn out torque converter is possible. Does it happen on light throttle going up a slight incline?
OP
OP
S
strity
mercedes benz vito
It seems to vibrate when i am accelerating up a hill but if i back off the vibration goes away
BlackC55
That does seem like a torque converter issue.
Needs proper diagnosis firstly
OP
OP
S
strity
mercedes benz vito
Also when it is cold, if i have driven a few hundred meters and stop for a few minutes, when i drive off it seems to stay in first for 5-10 seconds then changes up but only rarely does that. The vibration is worse when i accelerate hard. Thanx for your input, regards strity.
JasM
Scotland
2014 Range Rover SDV8 Autobiography
How many miles has it done?
JasM
Scotland
When was the ATF last changed?
OP
OP
S
strity
mercedes benz vito
the fluid was changed recently and engine mounts are fine. There is a klunk sound when i engage gear or when i accelerate after coasting, I hope that helps in diagnosis.
Sriandy
Vectra
I'd say torque convertor and prop coupling for the clunk
OP
OP
S
strity
mercedes benz vito
the vibration/shudder happens when accelerating in 2nd and 3rd gear and between 60-80kph, a few people have said it sounds like the torque convertor, does anyone think it could be the auto transmission?
Dieselman
Banned
Peugeot 403 Convertible
It's more likely to be the torque converter lock up clutch.
