didn't go for Command in the end :0(
I was basically in for the thick end of £800 for sat nav functionality, not sure i'm going to use/need it that much...
anyway, bought a head unit that will give me all the functionality i need ('cept sat nav) and is compatible with my CD changer.
but i can't make it work!!!
i figure that i will be taking it to an installer, but before i do, maybe if i describe what i've done, there may be a helpful hint
i connect the NEW pioneer head unit up in an identical fashion to the way the OLD pioneer head unit was connected
I have a relay and fuse sitting across the 3 power connections (constant, ISO and wiring harness)
problem: no sound....
the cd in the unit works
the cd changer is being controlled
the tuner is tuning
so i am confident power is getting there
but no sound
i have checked all connections and there are none loose
I experience no sound but a working unit with and without the relay/fuse in the setup
seems odd everything else works, just no sound at all?
any helpful hints would be gratefully received...
the tuner is tuning
but no sound
