OneForTheRoad
- Apr 20, 2015
- Location
- uk.
- 2024 Audi sq5 - 2019 Glc coupe 350d was 2017 e350 c207 .. +65 ford kuga 2.0 cdi zetec awd..
Isn't the irony the perceived need for turbo blanketsI think you most missed his irony!!!
There is a benefit the blanket could bring. But if I say what it is, everyone will want one.
Not saying its all true.....but google says....
Turbo blankets provide several benefits, primarily focusing on performance, protection, and reliability. By insulating the turbocharger, they help to retain heat within the exhaust gases, leading to faster turbine spool-up, improved throttle response, and cooler intake air temperatures. They also protect engine bay components from excessive heat, which can prevent damage and improve overall reliability.
Here's a more detailed breakdown of the benefits:
Performance:
Protection:
- Faster Spool-Up:
Turbo blankets help to keep exhaust gases hotter, which in turn increases the pressure and speed of the turbine wheel, resulting in quicker turbo spool-up.
- Improved Throttle Response:
Faster spool-up translates to more immediate and responsive throttle response, allowing for quicker acceleration.- Cooler Intake Air Temperatures:
By reducing heat soak in the engine bay, turbo blankets can help lower intake air temperatures, which can lead to denser and more oxygen-rich air, potentially increasing power output.
Reliability:
- Component Protection:
Turbo blankets help to shield nearby components, such as intake manifolds, intercoolers, and fuel lines, from excessive heat, preventing potential damage.- Reduced Heat Soak:
By containing heat within the turbocharger, turbo blankets minimize heat soak in the engine bay, which can reduce the risk of overheating and related issues.
In summary, turbo blankets offer a combination of performance, protection, and reliability benefits, making them a valuable addition for many turbocharged vehicles, particularly those with aftermarket turbos or those looking to optimize performance.
- Enhanced Reliability:
By protecting components and reducing heat soak, turbo blankets contribute to the overall reliability and longevity of the turbocharger and other engine components.- Improved Engine Health:
By minimizing heat stress on the engine, turbo blankets can help prevent problems like head gasket failure, which is a common issue in turbocharged vehicles.
Nope, none of the above. And, a much more useful benefit than all of those combined.Not saying its all true.....but google says....
Performance:
Protection:
- Faster Spool-Up:
Reliability:
The Alfa Romeo MiTo QV apparently.....never seen under the bonnet of one though.More benefits for a petrol than a diesel I'd say . Apparently a certain Alfa comes as standard fitted with a turbo blanket.
Lighter wallet after buying one??You are all barking up the wrong tree. But there's a benefit to be had.
It'll be OK; when the turbo goes bang, the blanket will neatly retain all the bits.I'd consider what happens when you switch off the car: The heat in the turbo (and everywhere else) has to dissipate. If that rate of dissipation from the turbo (and the oil in it) is slowed then the oil would be hotter for longer, hence probably degrading it (best case) or perhaps carbonising it (worse case!). Just a thought.
What is ODI?We used to lag the turbo as a means of increasing thermal stress on the engine oil. Shortened the ODI nicely.
Oil Drain IntervalWhat is ODI?
Normally OCI I think....oil change interval.Oil Drain Interval
