Turbo Reconditioning - Best Place?
alistairi
E320 sport
Can anyone recommend a good turbo specialist who'll recondition an OM642 turbo?
I have a W211 E320 CDI, the engine had gone into limp mode and was reporting a fault with the inlet shutoff motor. Before the fault it used to smoked heavily, after a long idle, and I noticed the end of one of the turbo vanes had broken off.
I plan to change the shutoff motor and clean the EGR in addition to sorting the turbo - it'd also be helpful if anyone can suggest other potential problems I should look at, now I've pulled the turbo off - e.g. change the oil cooler seal?
Thanks,
Alistair
If the housings are ok you can buy a replacement core from london turbo's, easy diy job.
Turbo dynamics have just refurb'd my turbo housings, and I got a new core from turbo rebuild (who, as the name suggests, can rebuild as well as sell parts)
Both great, would go with turbo rebuild for everything if I could have done.
New, Reconditioned & Remanufactured & Turbo Rebuild Parts
We use Midland Turbo all the time
