My 205 C Class was new in December. It's in the dealers today so they can try once more to fix a dodgy speaker or two.....
The Satnav in the C-Class is very, very good except a weird little quirk. I'd not asked about it on here before as I figured that this was just how Mercedes do it! But I've borrowed a CLA and the Command Satnav in there didn't seem to exhibit the behaviour. So my question is 'is this a weirdness of the C-Class 205 only or do others do this and is it likely to change with a software update?'
The behaviour:-
When approaching a bog-standard roundabout where you're needing to turn right (third exit), on about 3/4 of occasions the system will indeed read out the instruction to 'take the third exit'.
But on other occasions? It'll say 'turn half left'. By which it means turn onto the roundabout. It tells you absolutely bugger all more about which exit to take. If you glance at the display it gives you the accurate info but the voice just says 'turn half left'.
It's most likely to do it when you leave a motorway slip road. Up you go to the inevitable massive flyover roundabout with 6 exits. And it'll say to turn half left.
I'm sort of used to it now and thought 'quirky'. But either the CLA is different or I've struck lucky in the 100 miles I did today!!
The behaviour:-
