SANJP
Does This Command Unit For W211 Have Tv Input, Does Anyone Know ?
A 211 827 68 42
A 211 827 68 42
SANJP said:Does This Command Unit For W211 Have Tv Input, Does Anyone Know ?
A 211 827 68 42
A 211 827 68 42
Warning! Thread police alert!miro said:Why do we need a new thread every time there is a TV and COMAND question relating to the same car ?
He does have a point though.Flyer said:Warning! Thread police alert!
Maybe ... but Miro's post was before Alfie's. I read Alfie's response as "no point asking there as you're just getting a smart-aleck reply".Shude said:He does have a point though.
This thread is 100% pointless, as the only answer given was "call me". We have learned nothing!
Flyer said:Maybe ... but Miro's post was before Alfie's. I read Alfie's response as "no point asking there as you're just getting a smart-aleck reply".
Standing-by to be corrected though
SANJP said:MARK THANKS FOR YOUR HELP ON THIS HERE ARE TWO PART NUMBERS TOP IS THE UNIT THAT WILL ALSO ACCEPT INPUT AND BELOW IS THE NAV DRIVE
High Head Unit Teile Nr.:A211 820 2197 001
Model No.7039
DVD-Rechner Teile Nr.:A220 870 35 89 002
Model No.6059
THANKS
miro said:High Head Unit Teile Nr.:A211 820 2197 001
Head unit is not valid for TV, please refer back to your other thread where a photo of the rear of the head unit indicates the TV capable functions (green FAKRA connector) in conjunction with rear seat screen (DB25)
The Nav drive is the same for all cars but may need a firmware upgrade just for the run of the mill upkeep.
A 211 827 68 42 = no longer a valid part number (as explained)
One more time .... mo ichi do !
HOWEVER- there is such a thing as MODIFIED unit with special technique for attaching TV connector to such a COMAND that does not have it originally.
SANJP said:HI MIRO PLEASE LOOK AT THIS PICTURE OF THE ABOVE PART NUMBERS IM SURE THE HEAD UNIT HAS THE CONNECTERS AS THE PIC YOU POSTED ???
miro said:So that unit is which of the two part numbers ?
If that photo is of A211 820 2197 then something is seriously wrong. But if it is the other part A 211 827 68 42 then I cant say anything as it is no longer sold.
Either way ... what seems to be the problem ?
SANJP said:yes that is a pic of A211 820 2197 .
The point of all this is to make sure I order the correct unit with tv and rear screen capatability .
as to part A 211 827 68 42 I have seen pics of this unit and it definately has all connecters you said were needed.(green fakra and printer style conecter) as you state is no longer valid do I take it I shouldnt buy one ???
thanks Sanj
SANJP said:wow ! thanks for that
So in all i should make sure I get A211 820 22 97
May i just say the pics where sent to me buy a german company and I have no way of verifiying the parts numbers to pics .
thanks again Sanjiv
PS : TO ONCE AND FOR ALL STOP CONFUSION ON THIS MATTER FOR ALL FORUM USERS MIRO WOULD YOU BE SO KIND AS TO LIST ALL PART NUMBERS OF COMAND W211 UNITS THAT WILL DEFINATELY TAKE TV TUNER AND REAR SCREEN
THANKS
SANJP said:I,ll take that as a no !
miro said:You are doing all this to save $10. In the end you can save yourself all this fooling around and get the job done or try to beat the market with endless problems and strange suppliers.
Do you want a good solution or just to save a few dollars ? Who is going to install all this ?
