Skd884
- Sep 13, 2017
- i3
Two-car dream garages | Six of the Best
You've got a double garage and limitless budget - what should you buy?
www.pistonheads.com
Mine = 507 + LFA
Classy choicesMine would be:
For everyday
And for fun, the original super car.
Matt
Mine would be:
For everyday
Matt
Me too. They do have majestic proportions - exactly how a Bentley should be - but they would be very difficult to use in real life circumstances unless parking at the other end was both generous and easy to access.Actually I do have a real soft spot for the Brooklands Coupe, my word they are enormous though!
Honeslty I struggle a bit with the FF, the turning circle isn't great so any parking that's remotely tight is difficult and ends up with 7 point turns.Me too. They do have majestic proportions - exactly how a Bentley should be - but they would be very difficult to use in real life circumstances unless parking at the other end was both generous and easy to access.
One of the changes introduced on the GTC4Lusso was four wheel steering which helps with manoeuvrability - especially in cars with limited turning circle using the front axle only - but it doesn't make the car any narrower unfortunately!Honeslty I struggle a bit with the FF, the turning circle isn't great so any parking that's remotely tight is difficult and ends up with 7 point turns.
A Brooklands is another two feet longer but about the same width.
The doors also add an extra level of nuisance, they are so long you need a fair sized gap to open them enough to be able to get out. I often feel like I'm doing some sort of sideways limbo getting back in. Really not graceful.
