Datadogie
Was just watching a YouTube from Mercedessource. He was not not recommending when changing brake fluid to pump the fluid through the old way. (pumping the pedal) The reason being that normally when you brake your pedal never goes to the floor. But when pumping your brakes it does possibly doing damage to the unused parts.
So my question is . Is it best to suck the fluid through with a Pella pump or as I have. A system using the spare tyre pressure that pushes the fluid through the system. Or does it not make any difference which way it's done as long as its done.
