Hi New to MB and new to forum so sorry if dumb question. (Have searched but not found answer)
I have a 2007 ML320 CDI which uses the ABS sensor to compare rotational speeds and therefore determine variations in rolling radius.
However, I ran the right hand tyres over an obstacle in the road and staked both front and rear tyre. Both tyres deflated over about 8km (5 miles) but the tyre monitor did not indicate a flat. Luckily I caught the problem before wrecking the rims.
I took the car to the MB dealer asking to check the sensors and they said all ok. I know the system works for a single flat and it it highlighted a problem over about 1.5 miles.
I asked about the program to compare and they said it compared all four tyres not across an axle or one side to the other.
Two tyres going flat out of four I would have thought would have been enough of a problem.
They then said that it may take time (certain distance) for the system to work out the problem but had no real idea how it worked.
Can anyone shed light on how two flats on one side was not detected.
Thanks for you rforum.
Regards
1afc
Regards
1afc
