Tyre Rating and Suppliers
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by Scotsman520, Apr 19, 2012.
  1. Scotsman520
    Scotsman520 Member
    37
    Oct 19, 2011
    Car:
    E250 Coupe Sport Edition 125 Auto
    My E250 Coupe has a slow puncture that may need the tyre replaced.
    It has Continental 255/35R/18 tyres on it with a rating of 94Y.
    I have had difficulty getting one of these locally and the usual tyre centres are not confident of getting one soon.
    I notice online some of the other brands such as Bridgestone had tryes with a rating on 94W. I can get one of these locally today but not sure if it will be ok.
    The letter is a speed rating and I was wondering if I could mix that with the 94Y I already have on the car.
    Ideally I would prefer to have the same tyre but cannot wait too long, the spare is a space save job.
    Has anyone any experience of getting tyres via the main dealers or is that a non-starter. If so, who is the best for Continental tyres in the Central Belt of Scotland?
  2. Geoff A
    Geoff A Hardcore MB Enthusiast
    185
    Apr 3, 2009
    Oxfordshire
    Car:
    SLK280 Sport
    It's a load rating. Have you tried black circles and tyre traders on the web? You can get the tyre delivered and fitted too.
  3. Geoff A
    185
    Apr 3, 2009
    Oxfordshire
    Car:
    SLK280 Sport
    My apologies - the number is the load rating, the letter is the speed rating. I should read properly and not be in such a rush, but its been a long day.
    As long as the speed rating is above that recommended for the car, then personally I see no problem. Check the car's handbook and see what's listed.
  4. kam05
    kam05 Hardcore MB Enthusiast
    265
    Feb 16, 2011
    Car:
    C220CDI Sport (COMAND) W204
    I had a set of Vredstein Ultrac Sessenta's fitted a week ago- impressive tyres!
    Not sure if they do them in your size?
  5. Bobby Dazzler
    Bobby Dazzler MB Club Veteran
    15,740
    Jan 21, 2005
    Mittel England
    Car:
    ML AMG-line Black Series
    Mixing speed ratings isn't an issue unless you intend to exceed the lowest permissable speed.
    I personally would be more concerned about having a tyre which has a different tread pattern, tread depth, compound, etc. To reduce the impact, you could change both tyres on that axle.
  6. A-AvantGarde
    A-AvantGarde Hardcore MB Enthusiast
    4,685
    Nov 11, 2003
    South Bucks
    Car:
    2016 BMW F86 X6 M, 2016 BMW F30 320d, 2001 Mercedes C320 Elegance
    Info on speed ratings here:
    Speed Ratings - Tyre Speeds Explained | Blackcircles.com
    As Bobby has suggested, both tyres on the same axle should have the same tread pattern. If you only need a single tyre, it's probably best to source one online or from a tyre specialist (most tyre shops will order tyres for you).
  7. OP
    OP
    Scotsman520
    Scotsman520 Member
    37
    Oct 19, 2011
    Car:
    Thanks for the info guys. I agree re the tread patterns etc and will probably go for two of the same type if I cannot get the same as the original one. There is no problem in the tyre centres ordering one Continental for me, it is just the time involved as the tyre has had to be blown up twice today....dreading getting up in the morning if I dont have something sorted this evening.
  8. Bobby Dazzler
    15,740
    Jan 21, 2005
    Mittel England
    Car:
    Has anyone had a look to see whether it is a puncture and whereabouts it is?
    Maybe it could be repaired...
  9. OP
    OP
    Scotsman520
    Scotsman520 Member
    37
    Oct 19, 2011
    Car:
    Yes Kwikfit said that I had damaged the sidewall by driving it at low pressure (not flat) so they said. They did pin point the screw in the middle of the tread too. The tyre was not removed from the rim as they said they could tell by looking at it.
    1 person likes this.
  10. grober
    grober MB Club Veteran
    27,467
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
  11. Mr. B
    Mr. B Hardcore MB Enthusiast
    1,116
    Feb 11, 2012
    Car:
  12. HB
    HB Hardcore MB Enthusiast
    2,779
    Mar 30, 2011
    Car:
    C63 , E350 CDI, C320 CDI, SQ7
    Call Craig at Skidz in Falkirk. 01324 630060.
    He will do his utmost to help you and tell him Harry Butt gave you the number.
  13. OP
    OP
    Scotsman520
    Scotsman520 Member
    37
    Oct 19, 2011
    Car:
    Thanks again for all the info guys. I took the car to an independent tyre centre who removed the tyre and repaired the puncture. He said there was slight marks on the inner sidewalls but nothing serious. He is also going to order me a new Continental tyre but said I can drive about no bother in the mean time
  14. grober
    27,467
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    While visual inspection and experience will help in assessing tyre damage it really depends on how long you drove it in that partly deflated state [ from the screw presumably ] which may have weakened the internal sidewall plies of the tyre. I would be a bit circumspect driving with the repaired tyre till you get that new one fitted! That E250 Coupe is a powerful car putting a lot of torque through that tyre--- better safe than sorry.
  15. OP
    OP
    Scotsman520
    Scotsman520 Member
    37
    Oct 19, 2011
    Car:
    I totally agree with you. I want the new tyre on asap. The chap at the tyre fitter agreed to. Hopefully the new one will be in place early next week. The car was driven partially deflated for about half a mile to the nearest air line.
  16. Shude
    Shude MB Club Veteran
    13,914
    Jun 1, 2002
    Cheshire
    Car:
    CLK55 AMG
    This is exactly what happened to me a few weeks ago. Franchise tyre place told me they couldn't repair the tyre and tried to sell me a replacement (which they couldn't, as they don't stock winters). A local independent sorted it out without problem and sold me a set of summer tyres for a total of £10 more than the cheapest online sources. Another win for local independents!
Share This Page
