I have just noticed that my 2 front tyres (both PIRELLI ROSSO) look different in size diameter wise. One is a 245/40 ZR 18 93Y AO and the other is a 245/40 Z 93Y MO. The MO one looks larger in diameter than the AO one though the tyre size is identical,the gap from wheel arch to top of tyre is also about 5mm more on the AO side than the MO side. Can someone shed some light on this or am i going mad. Both front springs were replaced a year ago so im definately sure the ride height should be the same on both sides?
