Tyre size ? S204
Discussion in 'Wheels, Tyres, Brakes & Suspension' started by Alscoob, Apr 10, 2014.
  1. Alscoob
    Alscoob Hardcore MB Enthusiast
    111
    Sep 28, 2011
    Car:
    mercedes s204
    I have some nice C63 AMG 18" wheels, rears are 9" anyone know what is the best tyre size for this?
    Current 81/2" rears have 255x35x18 so should I go 265x35x18 so there is a bit more width to the tyre? maybe help a little to protect the rim? or just stick with the 255. Fronts have Conti 5's but these are not available in the 265 size, so if wider would need Conti 3's - is there a down side to the mix of tyres front & rear?
  2. DSM10000
    DSM10000 Hardcore MB Enthusiast
    3,995
    Jul 12, 2011
    Near Salisbury
    Car:
    E32O CDi Sport, C320 saloon MX5 1.8 Sport, RR 4.2 SC
    f you are increasing the wheel and tyre diameter you need ensure you maintain the rolling radius as closely as possible
    Search on line for tyre size calculators and you can see what will fit.
    Mixing tyres on front and rear may not suit the purists but is not a problem, just do not mix them on the same axle.
  3. OP
    OP
    Alscoob
    111
    Sep 28, 2011
    Car:
    mercedes s204
    Thanks, not really increasing tyre / wheel size as current ones are 18" it was more whether 265 is better on 9" as opposed to 255 section. I noted that you find both sizes of tyre on the C63.
    Agree would never mix tyres on the same axle.
  4. DSM10000
    3,995
    Jul 12, 2011
    Near Salisbury
    Car:
    Sorry, my error, reading the post on my phone I thought you were moving to 19"
    My point still stands though, if you increase the tyre width you ofen need to change the tyre profile (or aspect ratio as it s sometimes called) to ensure the same tyre diameter. The "35" is the tyre wall height expressed as a percentage of width.
    Tyre Size Calculator - Legal Requirements - Etyres
    You can play around with this calculator and see what combination gives you the closest overall rolling radious etc to the original fitting :)
    1 person likes this.
Tags:
Share This Page
