geoffd
I’m confused.
How should I store wheels/tyres when not in use on the vehicle ?
I have 2 sets of wheels – one with Dunlop SP Sport 2020 for summer use and one with Goodyear G3 Ultragrip for winter. Yesterday I started to fit the summer set, then noticed a nail or similar in the front offside. When I pulled this out it was about 10 mm long, but hadn’t gone all the way through although it must be pretty close, so I decided to check with the local tyre fit place whether it should be repaired. Repairing the hole was no problem, but they refused to do it because the tyre has some fine cracks at the bottom of the grooves – this they said makes the tyre unsafe and unusable. When I asked why this has happened they said it is generally because the tyre has been stored unused and inflated for long periods. Which it has, and the other front tyre is just the same. The back pair were replaced last year and are fine.
Being suspicious that maybe the tyre fitter was trying to drum up some business, I asked another tyre fit place about the repair and got exactly the same response.
These tyres are original (2003), have done about 20000 summer only miles and have about 3-4 mm tread left. When not on the car they have been stored horizontal in a cool, dry, dark shed and left inflated.
To try to make some sense out of this I started to look at internet tyre sites – and ended up totally confused. Michelin and some others recommend storage cool, dark, dry and horizontal but don’t mention inflation. Dunlop recommend cool, dry, dark, vertical and 0.75 bar pressure. None of the manufacturers mention age, but several other tyre sites suggest tyres should not be used beyond 6 (at the lowest) and 10 (at highest) years old. Nothing like agreement among the experts to give confidence is there ????
Question is though are these tyres past their use by date ? And has my storage method shortened their life ? Finally, and perhaps most important since I don’t seem to have much choice but to replace them, how do I avoid having a set of half worn but unusable tyres again in a few years ?
How do others store unused tyres ?
Any comments ?
Geoff
Any comments ?
Geoff
