D
Deleted member 65149
Guest
The good tyre on the OP’s car is one I’ve never heard of before but it gets pretty good reviews. They’re £140 each and with them being all that joins the car to the road I wouldn’t want to skimp by just buying one. I would definitely recommend getting a pair for the rear axle. It’s even more important on a big RWD car.As said, 4 would be ideal. But at least get a pair on the same axle as the one you're replacing.
Stating the obvious here but, you're measuring the depth of a groove, as the groove get shallower it's cos the tyre is getting smaller.
So a wheel on one corner with a new tyre has a total diameter greater than the one on the opposite corner with a worn tyre.
Ideally you wouldn't be rolling with one axle having a wheel with a 4-5mm smaller total diameter. It's going to be (albeit slightly) worse for handling, worse under braking, and both the tyres can wear unevenly then too. A bit like not having even tyre pressure.
Maybe it's not a huge difference, probably if you didn't know you might not even notice.... but it would bother me thinking about it while I'm driving if I did know.
Changing just one tyre now will lead to the same issue some time down the line when again one tyre will need replacing when the other still has thousands of miles left in it.
As mentioned by MJ earlier, I would also recommend a full wheel alignment check before fitting new tyres. For a rear tyre, the worn one does look oddly worn.
