UK best uhi phone retrofit installation harness part number?
perdikoula888
Banned
I have a w203 2002 UK model C-class. I was looking to find the most appropriate wiring (best one for upgrades) harness. I have found on EPC three part numbers:
A 203 440 22 10
A 203 440 48 05
A 203 540 36 34
what are the differences between them? Do they use different uhi controllers and if yes, which controller corresponds to each wiring harness? which one is the best? please let me know! :confused:
A 203 440 22 10 = UHI D2B
A 203 440 48 05 = UHI MOST
A 203 540 36 34 = UHI MOST + VOICE CONTROL
First of all there is one harness for cars with existing phones and a curly cord.
Second there are extension cables from the junction point under the ashtray section to the armrest or a long contact plate to the dashboard
Third there is the facelift version using MOST optical.
Fourthly, there is also a combined "full option" harness with everything in one big heavy cable.
Many possible variants just for UK.
perdikoula888 said:
Thank you for clearing it up. However is there a d2b uhi harness combined with voice/linguatronic option? I am trying to figure out what harness and modules CitronC230K_03 used in his car. Please check the following thread that shows the d2b uhi with linguatronic:
http://www.mbworld.org/forums/showthread.php?t=90078&highlight=uhi+armrest
Please let me know. thank you :confused:
You cant make sense of that since they have tele-aid prewired and all cars come with phone wiring. All steering columns come with the stalk hole for the lever and all cars are setup with the extra D2B cabling latently hidden in the trunk with the necessary VCS connector.
Steve would have installed the UHI conversion kit which takes the existing Nokia / Motorola setup and makes it UHI. Then just added the armest cable and trims. Its the first method as stated above.
Stick with using a VIN from a 2004 car with UHI and D2B that is UK based. Then you are safe. I usually get mine from used car lots (or as new cars over the years I spy the dealers).
Every time I see a variant, short run model I grab the VIN. Years later it saves me hours of farting around.
I dont think there is a combined harness for VCS in D2B since I buy mine stand alone and they click togther very nicely.
thank you once again. :) By the way, you mention that you personally used a seperate d2b voice/linguatronic harness. what part number did you personally use for your car?
*runs over to red VCS tub and looks into it for inspiration*
A203 540 43 06 - UK spec VCS harness for W203 sedan D2B.
I also ran the fully loaded W209 D2B loop some time back with BOSE, Phone, VCS, CD and COMAND (HU). That solved all of my optical issues.
I bought the D2B part from Steve MBENZNL since he seems to know the common items almost from memory.
Thank you once again! :) :) :) I figured out the three part numbers I need:
LINGUATRONIC
A 203 540 43 06
UHI
A 203 440 22 10
UHI – armrest harness
A 203 820 63 15
The only one I miss now is the fibre optical d2b full option harness. Which one did you use? Could you please let me know the appropriate best part number please? Thank you
The full option optical loop is in the garage (have several in hand) and I will look soon. If I dont please bump the thread
Thank you. I was checking epc... Is it the following?
A 209 540 47 07 (386+390+810+819)
The only one I found was for w209 clk I am not sure if it fits perfectly the c-class w203.
I could not find one for the c-class... please find the one you have to compare it with the one I found and please let me know.
Thats the D2B fibreoptics for a CLK with UHI, Lingua, Sound System and CD changer - I would get the C class part not the CLK part ..
Rather than replacing the whole fibre loom, you should just get some pieces and modify/extend the existing loom
Now, I think that in one of the door sills (probably right hand side) is where all the fibre optics come together and you get lots of couplers which allow you to re-order the ring and insert extra bits. If indeed you do have that, then you can order the appropriate part which should be the right length fibres to reach from the control unit to that patching place. You may need a D2B coupler as-well - which part number I can never remember.
To find the full set of parts, in the fibre optic section in EPC for C class, find the part A000 540 38 08 and look at the footnotes.
Alternatively you can order single bits of fibre, A000 540 38 08 ordered with ES2 code showing length (for instance 4260 = 4.260 metres) and the plugs to make up the end - the plug housings (straight or right angled) and the D2B connector is all in EPC in the same place mentioned above.
Ask your dealer nicely , there is a retrofitting linguatronic document for C class in WIS - or pay for www.startekinfo.com and go look it up yourself !
Richard
Thank you for the reply. The car I modify did not have any optical harness at all. Also I do not have previous experience in car optical harnesses and would like to get a complete solution for my first time to avoid possible surprises! As soon as I feel confident in the future, then I can start playing around with pipes of different lengths and connectors to make up my own optical harnesses.
At the moment I just look for the full option d2b optical harness for w203 but I cannot find it on epc. The only one I found was for w209, which practically is more or less an uprated w203 shassis therefore lenghths are more or less the same. However to be safe I asked MIRO to double check the part number and compare it with the one he uses for his car. can you also check epc and let me know if you see an alternative w203 number? thank you
I have used many W209 parts in my W203. Some of the most recent parts such as EIS, SAM and other modules are all labelled A209.
The UHI is labelled A230 (woohoo .... my car is 0.5% SL)
There is no major issue using W209 optics in a W203 because of the shape of the cable path and the length of the wheelbase. The head unit run is the most critical one. The trunk options are all the same in all aspects.
The CLK has a dip in the cable run inside the passenger rear trim panel which soaks up quite a bit of length.
Just use that configuration and it should be fine. (famous last words).
A 000 540 38 08 xxxx is the part number for ordering to length in mm
A203 540 70 09 is a useful cable with many options on it. I notice on this cable the CD stacker is optional and can be removed.
OK, use Miro's advice in the post above this - he is spot on as normal and has a lot more experience than me ..
(I only have only deconstructed my own cars over time A(169)/SL(230,129),ML(163),CLK(208),SLK(170) and helped add comand to a E(W210) as a hobby !)
But, do remember when you install you will have to loop out the units you dont use with a D2B joiner - very carefully so you dont bend the fibre too much - or the D2B fibre ring wont work ..
R
R
I recently started to acquire MOST connectors from Tyco. There is a REALLY COOL piece of kit from Tyco called a 'developer loop'. What it does is complete the ring in the smallest possible form factor without dismantling the open ring end (not much bigger than a MOST connector itself). It does it by bouncing the light 90 degrees twice inside a prism.
Too bad I never found the d2B version.
From now on you will see more and more cars using MOST and run across these loop closing connectors which are left in place of future devices.
If I ever make it UK I will be interested in swapping some more notes.
thank you miro and richard. :) :) :)
just to be safe miro, can you confirm that the part number you use in your car is the one below?
thank you once again!!! :D :D :D
Let me put it this way. Its in my car ..... really IN my car. I wont see it again till I go MOST some time later this year.
I have also supplied the W203 part number with the same functions.
One more thing. The optical loop with the most options is the most expensive. A quick and easy verification.
I went to my mercedes dealer, and the number below cannot be ordered, it is only an assebly number in the factory but not a spare part number. They told me that they can make a request for making a specific one in the factory. Therefore I have to join together 2 or three harnesses to make the one I need. Could you please let me know which ones to get then and join them together? My problem is that it is the last harness I left unfitted and need to get it ASAP in order to put back carpets seats, trims and panels to finish off my car and get it out of the garage which is not mine and they need the space. Please tell me what exactly I need to get. Thank you :confused:
You can add the phone harness and then get 2CD stacker harness for VCS and CD stacker. Steve is the guy with all of this stuff.
I went again to the dealer and had in stock the following optical cable harness:
A 203 540 13 09 (CD+UHI)
I tried to install it to my car (cd and command connected) but it is too short to reach the boot/trunk to be connected to the UHI controller. It only reaches up to the bottom B-right pillar. It ends with a 1pin single back joint connector and its pair is without connector. Am I doing something wrong? Souldn't it reach all the way to the boot/trunk? Or it means that a second wire harness required up to the boot.trunk to reach the uhi controller? :confused:
