Unconnected wires behind Command Unit
Reggie-rock
Northamptonshire
2015 E Class coupe 220 diesel bluetec, 2009 Mitsubishi Colt 1.3
At last removed my Command Sat Nav head unit from my 2006 CLK 350 convertible for repair, but found two wires going to this small connector behind the unit (pictured in my fingers) which was not plugged in anywhere, and seemed to be wound round other wires to keep it out of the way.
Does anyone know what this is for and connects too?
Many thanks.
Are the wires brown/yellow and red/yellow? Power for the fan motors in that case.
Yes they are those colours Diesel Benz. Where do they fit then?
Should go to Comand connector block #3, using pin numbers 1 and 7 there. The other end should be at the X120 connector.
