Thank you for that, sorry I'm new here and I didn't realise I got a response on this so quick. You've suggested a larger washer or a plate to cover, what do you mean by plate?Looks like part of an exhaust heat shield- they are usually alloy and secured by steel bolts leading to galvanic corrosion- can often be re-secured by use of a larger washer or plate to cover the enlarged hole in the heat shield before replacing the nut on the threaded stud
If the shield hole is large it may be difficult to find a washer of big enough diameter to hold the shield in place--- by plate I mean a thin bit of metal plate with a hole bored thro it to act as a large " washer"Thank you for that, sorry I'm new here and I didn't realise I got a response on this so quick. You've suggested a larger washer or a plate to cover, what do you mean by plate?
