Up-dating Sat Nav. S Class 320cdi.
BelfastBill
Grimsby
S CLASS 320 CDI
Hi my sat Nav is all over the place, Mercedes said it needed to go on the computer in the workshop for about 3 hours and would cost around £100+vat. There is a Navigation disc in the boot be side the CD changer magazine, and ideas? I thought I could just up-date the disc;I have seen some advertised on this forum.
Thanks' for any help.
Bill.
renault12ts
MB Club Veteran
2005 W215 CL500.
Bill.
They must be wrong. If you have the DVD based system it is just a matter of a new disc...which aint' cheap.
KennyN
Paisley
Me - BMW 440i Coupe / Dog -Cayenne
If it is all over the place does that not point to the antenna ?
Driving through fields that are now housing developments means it needs updated.
Kenny
Diesel Benz
Europe
222.132 & 213.012 & 906.633
Do you mean you sat nav is (significantly) mistaken about the correct position of the car? This most often means a broken GPS antenna. You could check from the head unit how many satellites it sees ("-" means an issue with the antenna or the cable).
OP
OP
B
BelfastBill
Grimsby
S CLASS 320 CDI
Thanks' how do you check from the head unit?
bob6600
AUDI S8 V10, S210 E320 CDI (R.I.P.)
Go into the engineer's menu and check the number of satellites it picks up
magpiemalemerc
northants
C-class AMG premium line
if you need a map update you don't need a disc just a sd card via mercedes download manager......if it's not working full stop try re-inserting the disc that came with it....
OP
OP
B
BelfastBill
Grimsby
S CLASS 320 CDI
Hi and thanks'all, been to a Mercedes specialist and it's the antenna, anyone know where best to pick one up please.
OP
OP
B
BelfastBill
Grimsby
S CLASS 320 CDI
I was hoping for an aftermarket antenna, as The dealers are expensive.
But thanks' anyway.
Bill.
