Uprated road springs W124
If they are painted red they ain't genuine Mercedes---- could be Ventura or other after market make - they might be H and R or Eibach - but should say so on the springs if they were in which case they may be worth a punt----- the fact the poster doesn't mention this poses the question???
For someone with a car with broken springs could be a possibility at that sort of price I suppose?
I had vernturas on my old car and was very happy with
These springs are GMax.
Gmax say in their advert they are shot peened which should help the stress corrosion fracture problem. Gmax - If you are looking for an Gmax Mercedes-Benz E 250D, 260, 280, 300, D, 320, 24V, Coupe, Turbo D Excluding 4X4 (1.1985>5.1995) Spring Kit Lowers by 40mm (30 MB 04) click here Gmax
However they do seem to have lost a bit of their protective coating and are starting to corrode- the fronts worse than the rears. the rears seem undamaged coating wise.
Problem with second hand springs as Bolide pointed out the cost+hassle of installing /removing them normally far outweighs any cost saving on price.
