Hi, this is my first post on the site & am hoping someone can help. My upshift delay has ceased to work. It would previously always work particularly from 3rd to 4th shift (auto obviously).
Everything I've ever read about this says that it delays upshift when cold in order to heat the catalyst quicker. However, I found that it would delay the shift everytime you would start the engine, regardless of engine temperature, even if you turned the engine off and started it immediately.
Anyway, back to the original fault. It no longer works. I've tested the vacuum going from the switchover valve behind the brake servo & still no improvement. I don't think it's avacuum fault but electrical.
Can anyone tell me if the switchover valve is controlled by a relay, and if so where is it. I can tell you it's not in the fuse box OR in the relay compartment behind that. The transmission otherwise performs as it should.
E220 W124,
722.4 four speed auto.
M111 engine
Any help would be appreciated
bubble124
E220 W124,
M111 engine
bubble124
