Urgent Help - Mid way through changing CPS
mr. shr
Guys,
I'm at my Mum's changing the crankshaft position sensor.
Got the old one out, but it's got oil on the end of it!!
Is that right? Thought they were meant to be dry?
Should I put the new one in?
A little oil is quite normal. Just put the new on in, it will be fine.
Just the response I wanted,
Cheers Olly.
The CPS employs a magnetic principle of operation so would be unaffected by slight oil contamination as has been said.:thumb:
New CPS is in.
No malfunctions but engine light is on.
Does it need to learn the new sensor or something?
Was the battery disconnected at all? Might be a fault was flagged when you disconnected the old sensor. May require the fault to be reset with Star or a fault code reader. :dk: Don't know what model your mother's car is?
It's a W211 52 petrol v6.
Took car to run a few errands and after a couple of starts the light went out.
Did a few more runs and still all ok so looks like job done.
Thanks for the help guys.:thumb:
