URGENT HELP NEEDED - STOP VEHICLE LEAVE ENGINE RUNNING
Did you fit the replacement battery yourself? Do check the tightness of the terminals, and also the 13mm nuts on the side of the positive terminal. Some people loosen these to give more room to lift the battery out. If the nuts aren’t tight the resistance will measure as too high
Hey man I forgot to mention this, when I charged my battery. The stop start feature started working for like 5-10 minutes it never did that prior to charging. This then went away after 5-10 minutes
You know MB dont manufacturer their own batteries? Most Mercedes batteries are Varta...
Yes, and Mercedes charge a crazy price for the same battery. Varta AGM 096 from Mercedes £324.40. Same battery from Tayna £152.06 delivered. That really is taking the P***
Some say the varta made for mercedes are special though. 🤔
Legend. The 13mm nut was loose, it got tightened. Now it’s working magic 🫡
