Urgent 'Warning light' help needed please !
Ron
Southport
E 300 TD Estate
I'm currntly on my hols in the Lake District and a warning light has just come on in my '98 W210 3.0TD.
It is the ASR warning light and "BAS" has come up on lhe dash.
How serious is this? Can I get home? nothing seems wrong !
Is it a 'stealership' re-set ?
Your expertise, as ever, would be appreciated.
Shude
Hardcore MB Enthusiast
Cheshire
CLK55 AMG
BAS / ASR warning light usually comes on when the switch breaks. Mine did that a year or so ago, just had the switch replaced and all was well, about £10 for the switch and it's about one hour labour, but I had it done during a service and they swallowed the labour.
While the light is on you won't have brake assist or ASR, you rarely need either during summer months (different story in winter!).
Brian WH
East Midlands
JAGUAR XF 3.0D Premium Luxury
Had this on my last E280 in Switzerland. Any brake fault can bring up this failure, from brake light switch failure to something more sinister.
My MB dealer told me that it is OK to drive if it is Intermittent. If it comes up every time you press the brake pedal it is likely to be the brake switch. No problem therefor keep driving, press reset and all is OK for a while. If the fault is serious then you will notice that the brakes are not so good. Then you need to take it easy on the way home M8.
Hope this helps.
Steve_Perry
Wales, U.K.
CLS350CDI Grand Edition
As Shude has said the most common cause for the ASR/BAS warning light to come on is a faulty brake switch. The manual also states that the engine mangement system will also turn off these systems if there is drop in battery feed voltage, I'm not sure of the thresh-hold figure, around 10v I think.
Having said that it's most likely to be a dodgy brake light switch. Again as Shude has said above whilst you're driving you won't be causing any further damage, the lights on the dash are just warning you that the brake assist and traction control safety aids are inoperative.
S.
OP
OP
Ron
Ron
Southport
E 300 TD Estate
Thanks to everyone who replied. Very re-assuring.
I've noticed that the dash shows "ACR" first, then you press the re-set, then it is "BAS". press again for the re-set. I hope this is the norm for a faulty switch and nothing more sinister !
Richard W
Berkshire
BMWs :-)
If all else fails there's a Mercedes dealer in Ulverston - can't remember the name, I seem to remember it's left at the second traffic lights after the roundabout going towards Barrow.
HTH
R
Aletank
Liverpool,UK
If It is a brake switch,sounds like it is, Road Range Liverpool charged me £54 inclusive to replace it.The job only took just over a hour while i waited for the car.
The dealer mentioned in Ulverston will probably do it while you wait if you phone first
Mercedes-Benz of South Lakes
Princes Street
Ulverston
Cumbria
LA12 7NQ
Tel: 01229 581681
Dieselman
Banned
Peugeot 403 Convertible
Not too bad I suppose given that the switch is £7 and it clips into place. Removing the trim panel under the dash is the longest part of the job.
Aletank
Liverpool,UK
I have my receipt here From Road Range Liverpool - 11/10/02
Fit OSF Brake Sensor
Total Labour £46.50
Part Number A 126 540 20 17 - Sender Unit - £1.32
Total VAT £8.37
Total Value £56.19
Due To Your Vehicle Being Over 3 Years Old You Are Now Given 25% Off Labour And 10% Off Parts
VikJ
Peterborough, Cambs.
2014 W246 B180CDi AMG Line Premium
My A160 is coming up with ASR/BAS lights and got it checked out. Apparently, the master control box (?) has gone and needs replacing for a cost of £700! That was with a Merc Specialist on the not the stealer!!!!
Thank heaven for Warranties! :D
Aletank
Liverpool,UK
AS you can see from my above posting my job cost £56 from the main dealer.
The first "specialist" I contacted wanted £120 telling me the part is £70ish, The second ""specialist" wanted £100
Always worth checking the main dealer for prices first.
OP
OP
Ron
Ron
Southport
E 300 TD Estate
Does this switch effect the cruise control as well. Because that has just gone tits up. I hope it's all the same problem.
Surely I'm not that unlucky !!!!!!!!!!!!!!
Shude
Cheshire
CLK55 AMG
I didn't get my BAS/ASR brake switch replaced for about 3 months, and all that time had to use the speed limiter rather than the cruise control for long journeys. Boy did I appreciate the cruise after I got the switch replaced ;)
OP
OP
Ron
Ron
Southport
E 300 TD Estate
All fixed now !
Took it to a Mercedes specialist, S&R motor engineers (Mercedes doctor) in Formby, Merseyside, as recommended by other members.
15 minutes later, fixed and only £20.
How's that for service ?
Alps
London\Essex
E55 2004 Silver(SOLD), E63 Weistec AMG(SOLD), E55 2004 Silver(SOLD), C36 AMG 1997 (SOLD)
what was the problem?
OP
OP
Ron
Ron
Southport
E 300 TD Estate
It was the switch after all.
So, new switch fitted and, the old one given to me to do what I like with !
Aletank
Liverpool,UK
pics please
Yep pics :D If my BAS/ASR light ever comes on again, I think I'll buy 4 new brake sensors for £1.50ish each and have ago at replacing them all myself.
