USB audio on A180: keeps skipping tracks!
po55kit
Cambridge/Nottingham
2015 A180
Ayup.
I have recently taken delivery of a new A180, a great car all round, but the aforementioned does annoy me.
I have a long playlist of tracks on a USB stick which is plugged in beneath the centre armrest. Occasionally, when a new track comes on, it will skip it immediately and move onto the next. Sometimes it will skip two in a row.
I can be sure that this is not me nudging the control wheel.
Anybody aware if the underlying problem here?
Cheers,
David
Can you try a different USB stick?
If you can ideally "faster" i.e higher through put.
I had odd behaviour similar to that in a non Mercedes car and changing the USB stick helped in that case.
Hope this helps
thanks p
