Or 90 octane and 95 Octane?Are you talking about E5 and E10 petrol? DO A SEARCH ON HERE
I don't have the manual do you know where I can download it?What does your vehicle handbook recommend?
What changes will I feel when driving or any engine issue will occur later onIt will be fine.
90 octane and 95 OctaneAre you talking about E5 and E10 petrol? DO A SEARCH ON HERE
yes 90 and 95 OctaneOr 90 octane and 95 Octane?
In Jordan we have 90 and 95 OctaneWhere can you buy 90 octane fuel ? not in the UK and some other countries don't have equivalent octane ratings to ours. Most countries use RON as the octane rating but some like the US use (RON+MON)/2. The US octane rating numbers are substantially lower than ours for this reason e.g. 90 octane in the US would be somewhere close to 95 octane in the UK.
I
I dont know which one to use that's the question?So if you have both available, why not just use the correct fuel then?
Where can I find this info?
In the handbook for the vehicle or the fuel filler flap.I dont know which one to use that's the question?
Yes it does say thatThere should be a sticker inside the fuel flap, it will have the tyre pressure figures on it, and it should also say '95 RON'.
I found one for E350 not E350eIn the handbook for the vehicle or the fuel filler flap.
Handbooks can often be found on line. Try searching.
May I suggest you add your location as it will make it easier (and relevant) when responding to you plus avoid misunderstandings. Cheers!I
JordanMay I suggest you add your location as it will make it easier (and relevant) when responding to you plus avoid misunderstandings. Cheers!
