SilverSaloon
- Mar 16, 2004
- 1994 W124 E300D Estate, 1985 R107 280SL
My problem is that i can afford to buy one BUT the problem comes when something goes wrong. The odd oil change here/there isn't a problem but something big costing many £100's or even into four figures would cause my wife to chop of vital parts of my body....
i just don't know if i can take that chance.....
In one way would you be better off with a cheap one and take a chance - if something horrendous happens and that isnt likely if you buy with caution, you can sell it on and get another.
OR you could take the risk and buy a top end one that hopefully wont go 'as wrong'.
I would go for the top end one, look for history - not necessarily FSH i mean whats been replaced/repaired out of normal servicing stuff, ie bearings, steering stuff, etc etc.
It will probably be fine - the good thing is whatever goes wrong you can always get 2nd hand replacements so nothing should really run into four figures..... you can get a whole car as a rotter with engine and gearbox perfectly good for under a grand and transfer the stuff over if the worse did happen. I doubt that would be needed though as there are plenty of breakers out there.
