Using Heat to repair spoiler damage ?
Discussion in 'Bodywork' started by tjamesbo, Jan 8, 2017.
  1. tjamesbo
    tjamesbo Hardcore MB Enthusiast
    563
    Jan 6, 2007
    Sutton Coldfield Midlands
    Car:
    CLK430 ,Vito V6 sport ,Jaguar 2.5 X type ,W124's 1993 220TE , 1994 320TE ,Mastercraft X5
    Heres the Damage few mph on a low kerb in car park underside its deformed in and this has pushed the front face out what I'm wondering is whether I can use a heat gun and some wooden blocks to get it back to near its original shape Its my sons BMW 335i.
    Any Tips ??? current thinking is nothing lost in trying could a specialist do anything ?
    Boyd
    [​IMG]
  2. noogieman
    noogieman Hardcore MB Enthusiast
    1,867
    Sep 20, 2005
    EU
    Car:
    My dream: Der Hammer
    i saw a video on youtube with a guy pouring hot water on his dented front bumper then from the inside of the engine bay just carefully pushed out the bump with his fist.
    that was an interesting video to watch.
    maybe you might be lucky fixing your dent?
    1 person likes this.
  3. brucemillar
    brucemillar MB Club Veteran
    8,663
    Nov 18, 2010
    Next Door to Alice - 25 'kin years now
    Car:
    C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
    A heat gun used sparingly and from some distance may do the trick. I would take the bumper off first and heat from the inside.
    I tried this on my 124 rear bumper and had it almost to perfection..... Then, I thought I would just do that one last bit. The bit that actually didn't really need doing. DISASTER. I had to buy a new bumper. Just that extra second of heat and the plastic changed it's surface finish and in cooling shrunk the dent back to worse than when I started.
  4. Dec
    Dec Hardcore MB Enthusiast
    4,475
    Jul 28, 2004
    Car:
    C180,A.
  5. OP
    OP
    tjamesbo
    563
    Jan 6, 2007
    Car:
    Great Tip that the Hot Water , kettles on the boil now just about to try it :D
  6. Tombola
    Tombola Active Member
    87
    Jan 18, 2016
    Hampshire, UK
    Car:
    C63 AMG
    Looks like he has cracked the paint, so will need spraying :(. Interested to see if the hot water trick works though!!
  7. brucemillar
    8,663
    Nov 18, 2010
    Car:
    remember to remove your shirt, shoes & socks before going in.
  8. OP
    OP
    tjamesbo
    563
    Jan 6, 2007
    Car:
    Result :D Poured kettle on it (after taking off shirt socks etc:D ) and heres the result there is a small bulge left but given where it is ie about 4 inches off the deck a blow over and fade in down there and it should be acceptable . Had to glue some metal strips on where the plastic attachment for the arch liner had torn and its knackered the headlight washer unit on that side but a result cheaper than new Bumper spoiler which is what he thought he was looking at
    [​IMG]
  9. brucemillar
    8,663
    Nov 18, 2010
    Car:
    Excellent work.
  10. niknakmb
    niknakmb Active Member
    82
    Sep 17, 2016
    Car:
    a ford :-(
    I'm not sure but It may fail the mot if the headlight washer is broken.
  11. OP
    OP
    tjamesbo
    563
    Jan 6, 2007
    Car:
    Plan is to fit a new washer which unfortunately means removing it all again :(
  12. noogieman
    1,867
    Sep 20, 2005
    EU
    Car:
    I'm glad my hot water tip worked out for you. :thumb:
  13. Marku
    Marku Hardcore MB Enthusiast
    748
    Dec 18, 2012
    Car:
    Viano Ambiente 2.2CDI W639, S-Class 450SE W116
    Be following this thread with interest as I have been living with a creases offside rear panel for some time. Managed to jackknife a trailer into it and have been working up to a visit to the paint shop. MB would not make any attempt at repair and just wanted to replace the panel. Will definitely have a go myself didn't know hot water could be so effective.
Share This Page
