V slot wiper blades.
toteimerced
C 220 CDI sport edition
Hi, can anyone please tell me how to change the wiper blades on my 2006 c220cdi? They are the v slot fitting type, thank you.
I had a 2006 W203... and I am not sure what you mean by 'v slot'?
I think it's the generic name given to the type of fitting on this car, Audi also use the same type I believe.
No that's the old hook type wipers, mine are the flat earo type used on most modern cars, I'm just not sure how they come off the wiper arms, it may be obvious when I receive the new ones, which I waiting to be delivered.
Okay chaps, I found a video on YouTube of an Audi A4 wipers being changed, which are exactly the same as the Merc, funny though, no video with Merc's, only the newer models. Cheers.
I thought they were "toplok" wiper blades, and you remove/install them by moving the "lock" part back then simply lifting the arm off the blade.
Yes, you slide the plastic hinge cover away from the hinge, quite stiff, then they just lift off the arm.
