- Dec 28, 2007
- Volvo V90 D5 AWD
And I could give up the camping trips and just kip in it, ideal!!!
And go beaver hunting .
... like a shrinking violetBang on topic RM,
This is my beef with the kickdown - it hesitates, which is annoying.
Something that did help the gearbox become smoother (apart from the ATF change)... was me changing the air filters
On inspecting the ones I replaced; they were really badly clogged!
I've had the car a year during which I had a new turbo under warranty, and as part of the diagnostics process leading o the new turbo- the air filters were replaced... or were they?
Not that I'm the suspicious sort... but the way I see it; filthy filters is probably old filters
There is a lot that is not on the MB UK price list that you can still factory order, they just don't put it on there to discourage people from ordering it. As long as they are putting the 5g in high end cars you will still be able to spec it in any other car as a direct factory order (for a price of course) the reason is the 5g box will handle 796lb/ft torque whereas the 7g will only handle 542lb/ft to me that says it all why the 5g is better than the 7g.
I recall our air filter discussions on a previous thread.
What was wrong with the turbo - did it show as a fault on the display?
and my car pulls from standstill to sillyness without any fuss.
which high end cars would that be?
not a 4 pot C class or a 4 pot E class surely?
Mercedes dealers in Germany say that as long as MB are producing 5g boxes for such cars as chrysler 300, dodge charger, jeep grand cherokee, Chrysler cross fire , MB S65, S600 SLR then you can (for a cost ) spec the 5g box in any MB car.
don't know if anyone else has noticed this but i get a far smoother and quicker pick up by not using kickdown? It's like kickdown just confuses the car and gearbox but when i floor it the power is there and the gear changes are far smoother?
I bet a UK dealer won't do that for you
I bet you are correct, such is my disdain of UK MB dealers if I do replace the Volvo with an MB it will definitely be ordered from a German dealer. They appear to be able to offer things UK dealers simply can't or won't. They are much more amenable to you speccing the car exactly as you want it.
Strangely enough with BMW ban it's the other way around UK dealers offer options the German dealers don't or won't match, bizarre
7g-Plus 'box seems to have fixed that. Two versions with max torque of 700Nm (516lb.ft) and 1000Nm (738lb.ft).the reason is the 5g box will handle 796lb/ft torque whereas the 7g will only handle 542lb/ft to me that says it all why the 5g is better than the 7g.
So you could order an C350Cdi with 5g. Oh good god, my dream car is out there.
Was the engine software updated as well as the gearbox as they should be done together. If the air filters are replaced the engine ecu should also be reset via the star machine. This makes a difference. Resetting the drift compensation for the maf can also help.
Last year my E320 needed a "major service" and the air filters etc were changed at that time. I used an indie that didn't have a star machine but had software that could read codes etc.
I wouldn't have thought that anything would have been reset at that time?
Also when i had the atf changed (which i found hadn't been changed in 110k miles!) i don't think i had the box reset or the software updated so would this cause the issues i have mentioned in my previous posts?
The indie i went to for the atf does have a star machine, but would he have done the above as part of the process?
Will this cure the problem. I have heard a little on it but seems good
eBay - The UK's Online Marketplace
rascalmaster said:"I wouldn't have thought that anything would have been reset at that time?"
- i doubt it. star settings post air filter change while desirable, are not imperative.
"The indie i went to for the atf does have a star machine, but would he have done the above as part of the process?"
- doubt it.
