rascalmaster
- May 5, 2010
- Location
- harwich, essex. UK
- Brabus D5 (E280 CDI) Avantgarde, E280 CDI Sport Estate, E320 Avantgarde now sold
Would you recommend I get the box reset and have the software updated? Is this likely to make changes smoother and less prone to holding onto gears up to 3500rpm when I am not putting my foot flat to the floor?
I am finding my gear changes to be really erratic just lately and a car like this just shouldn't behave this badly
Resetting parameters and making sure you have the latest software will hopefully help.
As you know the box stores info about your driving style and then adapts itself accordingly.
When you start afresh; you can also teach your box when you like to change up by moving the gear selector right at your preferred rpm/speed.
I have also found leaving the car idling for 3-4 minutes in 'p' seems to settle it a bit.
There is another accelerator reset you can try. Respected indies say this is just a placebo effect and does nothing. Others (myself included) feel it works.
I suppose you have nothing to loose...
1. When the car is warmed up, switch off the engine.
2. Turn the key/ ignition to position 2 (this is the position to just before the car would start).
3. Push the accelerator down all the way down past the kick down and hold it there. Count slowly to 5...
4. Switch off ignition completely. Count slowly to 5 again.
5. Now release the accelerator.
6. Wait 3 minutes. You may hear a whirring noise at the end of this period.
Now have a drive and see if the car feels different...
A good Indie (I swear by Olly in horndean) will soon plough through and hopefully sort out your box.
See olly's post here about changing ATF fluid... and you'll realise it's not a simple case of 'out with the old and in with the new'.
These are complicated cars and need some TLC... I found changing my air filters, and engine oil and filter made the car much smoother and the gear changes much more refined!
